01-02-2018
19:55
05:23
SelmaFitbit
01-02-2018
19:55
05:23
SelmaFitbit
I am trying to connect my LG Tone wireless head set to the new Fitbit Ionic. Can anyone tell me how or if they will connect?
Moderator edit: removed label
Best AnswerI found out how to get the LG Tone Pros into pairing mode. These instructions are not included when you purchase them. I had to google how to pair LG. With the LG off, press and hold the call button then turn the headphones on. The blue indicator light will flash and then stay solid blue. Now you can go to the ionic settings Bluetooth new device and the LG headphones will appear. Tap on it and it will pair. The tone is wonderful. Finally. Hope this helps others.
Hi, @bbloomgren! You shouldn't have any issue connecting them. Check out this help article for instructions.
MakMak | Community Council
This didn’t work for me. I tried by following the Versa touch screen Bluetooth settings (just like the link showed that was provided) and it wouldn’t recognize my Bluetooth headphones. Is there any other troubleshooting that I can do?
I am having the same issue with some basic X3 sport headphones. I've restarted my Versa, and it still won't connect. Trying to figure out what the issue is without having to buy new expensive headphones.
Woohoo, this helped me! Thanks so much! I couldn't figure out how to get the headphones into "pairing mode." Hold the call button, turn it on, then you'll see the blue flashing light, and the headphones will tell you they're in pairing mode, as the light turns solid blue. I unplugged them to see the light more clearly.
Best AnswerThis helped me! Thank you!
17:10
10:25
SantiR
10-10-2018
17:10
10:25
SantiR
Omg thanks so much!
When phone is off press call button. Keep it pressed while turning it on. That worked for me. When I pressed call button and then released and then turned on it didn’t work.
Moderator Edit: Merged User's Posts
10:33
06:26
10-23-2018
10:33
06:26
@HopeDymond Welcome to the Fitbit family! I'm really glad to read that you found some solutions on this thread and that you are back on track now.
I went ahead and marked the most helpful post that included the workaround as an accepted solution. This way, other users will be able to find the solution to this faster. Thanks for confirming that this worked for you too.
Also, take a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with on challenges, check this thread to add some!
See you around! ![]()
10:51
06:26
12-25-2018
10:51
06:26
@Adiblasi Welcome to the Fitbit forums! Thanks for sharing your results on this thread after trying the steps provided.
I'm really glad you are back on track. Hopefully, this will be helpful for more users.
Additionally, have you checked the Feature Suggestions Board? If you have any ideas for future features you would like to see on your Fitbit device, this is the best place for asking. Feel free to search for existing feature suggestions or add you own original one!
