07-22-2019 09:06
07-22-2019 09:06
So for the last 2 days the time on my fitbit seems to be 10-15mins behind the actual time. I have my settings set for it to auto update from my phone and the time zone from my phone. Which i guess would work but it won't sync!!
i have had my fitbit for 6 months now and have had constant syncing issues. Like it wont sync for 2 days then randomly at 2am will sync. This means any runs that i track i cant see the details of on the app or in my linked strava account for days sometimes. Today the app says it can't find my Ionic at all. It synced this AM when i was running in the middle of nowhere. But now i can't sync my run i did as it can't find the fitbit.
I've restarted the watch and my phone multiple times, reset the wifi/bluetooth multiple times, tried syncing through the windows app as well as the android app (Samsung S9 so a approved device), uninstalled and reinstalled the fitbit app. The only thing I've not done from all the posts with similar issues is a hard reset as i don't want to lose the data of the 12mile run i'm still waiting to see!!
These issues have been there since day 1 but the new update seems to have made it worse. The stupid thing now doesn't even function as a watch as it has the wrong time!!
Any ideas of how to fix without deleting my run data?
07-23-2019 08:42 - edited 01-01-2020 11:03
Hi @Alfiesam, nice to see that you're digging into the Forums. Thank you for troubleshooting this beforehand by restarting your phone and device, between some other steps you've tried too.
Sorry about the syncing issues you're having with your Fitbit device. I'd advise to turn off all Bluetooth devices around the room. If you can delete your Fitbit Ionic from your Window 10 device it would be better. Also check your phone Permissions and leave location on to keep syncing and getting notifications with your phone, for more info check this suggestionsfrom @ErickFitbit. ![]()
Check some requirements that your phone and Ionic should have in order to successfully communicate:
Requirements:
If the syncing issue remains with a mobile device I would recommend following the steps below:
Those steps wont delete your recent information, all details should be safe on your Ionic.
If there is anything else we can help you with, do not hesitate to post it.
Best Answer07-23-2019 10:33
07-18-2021 16:34
07-18-2021 16:34
I have spent 3 months trying to get my versa to work.
Now I am getting an iphone and apple watch. Not worth it for this piece of crap that never works. Toss it in your burn can!
