01-26-2019 04:04
01-26-2019 04:04
I have a mid range pair of Bluetooth Headphones to use when running. Whenever I use it there is interference everytime that I pull my arm back as a run. So basically the music cuts out twice every second .you can not imagine how annoying that is.
Is anyone else experiencing this?
I want to know if this is a common problem before I go and spend alot of money on an expensive pair only to find out that they won't work either .
01-26-2019 08:06
01-26-2019 08:06
@GHaynes wrote:I have a mid range pair of Bluetooth Headphones to use when running. Whenever I use it there is interference everytime that I pull my arm back as a run. So basically the music cuts out twice every second .you can not imagine how annoying that is.
Yeah this is a common reported problem. Solution that might work is to move the Ionic to your other wrist. Try that and see if that helps.
I have Jabra Beats Sony that do not cut out. So some work and some do not. Is kinda hit and miss unfortunately.
Best Answer01-27-2019 08:23
01-27-2019 08:23
This happens because of the small antennas meaning a smaller signal. I'm not sure if there is a fix without changing hardware
03-23-2019 09:23
03-23-2019 09:23
I have an Ionic and am experiencing the same issue with some new JBUDS Air earbuds. They seem to work fine at home but at the gym the connection is really bad. I have tried switching wrists but that doesn’t improve the connection. Has anyone found a pair of wireless earbuds that seem to work in public places?
