09-30-2017 21:49
09-30-2017 21:49
This happend during i erase my data.
I disconnect pair and what should i do?
please help me
10-01-2017 22:53
10-01-2017 22:53
I have this exact same issue. The device won't reconnect to phone and there's no way to get to any menu on the unit. It's basically bricked. Just a big red cross on the screen. With "Data not cleared Sync & try again"
10-02-2017 00:21
10-02-2017 00:21
I have same issue: Does somebody has any idea
10-02-2017 00:59
10-02-2017 00:59
I have contacted the support,here the solution:
1. You need to delete the ionic in the app
2. Remove the ionic in the bluetooth profile
3. Install the ionic in the app again
4. If there is no connection,press all three button at the ionic
that's all 🙂
10-21-2017 13:52
10-21-2017 13:52
Not sure if you already had your issue solved, but just incase someone else needs:
Today I spent 30 minutes on support tried all that (and more), to no avail ... uninstalling apps, reinstalling apps, tried hard resetting the tracker many times, wouldn't reset ... app couldn't find tracker in order to update the firmware, etc. Begrudgingly tried installing the app on my husbands phone at request of support ... all of the same issues, app couldn't find tracker. They escalated it, I dropped off the call ...
Then I decided to try some other things from his phone (S G6) since I had the app up, and chose in the settings "Replace Device" to see what would happen and it worked, tracker immediately responded, it popped up and restarted, I setup the wifi, and ... voila ... had to the through the setup again (bummer waiting for it again), but it worked. Logged off the app on my husbands phone, reinstalled the app on my phone (S G5), logged back in, good to go.
10-26-2017 23:27 - edited 10-27-2017 00:24
Any update or solution? Should we just send the bricked devices back?
I managed to connect the watch to a different phone with a different Fitbit account.
Then tried to reset it to connect to the previous phone/account (the real owner) and got the "Data not cleared. Sync & try again".
10-27-2017 03:55
10-27-2017 03:55
I have been in email contact with Fitbit support. It looks like they are going to send me a shipping label to send it back to them, but I haven't received it yet.
11-08-2017 08:14
11-08-2017 08:14
Well I have now received my replacement Ionic from Fitbit. Nothing we tried worked.
All I can say is - if anyone is considering factory-resetting their Ionic, I would avoid it unless absolutely necessary. If you are going ahead, I would sync the Ionic first and then attempt the factory reset via the Ionic menu (Settings >> About >> Factory Reset) rather than using the three-button method (like I did). I have no idea whether you need to unpair your phone before doing the reset, but the post above suggests that you should.
The fact remains that my Ionic was left in an unrecoverable state after performing a factory settings reset. This is ridiculous - if there is an operation to reset to factory settings then it should do exactly that, not fail if a pairing is still in place and then leave it in a state where no further action is possible to recover the device.
I for one will not be resetting my Ionic again unless directly told to by Fitbit support. As far as I am concerned the factory reset operation can not be relied upon to restore an Ionic to a working state.
11-17-2017 23:40
11-17-2017 23:40
For the first time, I "factory reset" the Ionic from Settings>About, but it also failed.
My configuration:
Ionic was unpaired from the mobile app
Ionic was not unpaired from the bluetooth
Ionic was running a developer version OS
Ionic had a sideloaded clockface
11-18-2017 02:34
11-18-2017 02:34
@robocope wrote:For the first time, I "factory reset" the Ionic from Settings>About, but it also failed.
My configuration:
Sorry to hear that. Have you ended up with the red cross and the message sync & try again?
If so, have you managed to re-connect your Ionic to your account using the Fitbit app? If not, what error do you get? What device are you using for the Fitbit app?
11-18-2017 16:23
11-18-2017 16:23
yes, reconnecting to a device works.
11-18-2017 23:50
11-18-2017 23:50
I would like to confirm resetting worked after unpairing from bluetooth (forget this device on apple devices) and delete the ionic from the fitbit app.
11-19-2017
00:03
09:04
11-19-2017
00:03
09:04
@robocopeThere are many variables and I have had daily syncing by doing this and if that fails I will resort to all of the other options. But to date, since the Ionic was released I haven't had an issue other than below.
Ironically when I restart the Ionic the syncing never detects that there is no Fitbit..
While out in my front garden, gardening and the phone inside.. I was getting notifications from 4-10 metres away and the shorter distance had a sisalation paper insulated outer wall..
11-20-2017 05:36
11-20-2017 05:36
@robocope wrote:I would like to confirm resetting worked after unpairing from bluetooth (forget this device on apple devices) and delete the ionic from the fitbit app.
Out of interest, did you reset from the Ionic menu or using the 3-button method?
So far from the responses above, it looks like you may be able to safely reset using the settings menu on the Ionic, if you have unpaired the Ionic from Bluetooth and deleted the Ionic from the app (before resetting the Ionic). At the very least it looks like you will still be able to re-add the device even if you get the red cross and Sync & Try Again.
11-23-2017 02:59
11-23-2017 02:59
I tried from the OS under About. Is physical button reset just a shortcut to the same reset operation?
12-06-2017 06:58
12-06-2017 06:58
Hi this usually happens when you performed a factory reset without before unpairing the device. Usually you should unpair the device, forget BT (both Ionic and Ionic (Classic)) and perform the factory reset. To solve this issue follow these steps:
Hope it helps, it did work for me 🙂
12-06-2017 07:23
12-06-2017 07:23
@acuatico69 wrote:Hi this usually happens when you performed a factory reset without before unpairing the device. Usually you should unpair the device, forget BT (both Ionic and Ionic (Classic)) and perform the factory reset. To solve this issue follow these steps:
- Unpair your Ionic
- Unpair from BT both Ionic and Ionic (classic)
- Restart the App
- Setup your device again.
- Probably you will need to perform another Factory Reset because not all Data has been erased. (Remember to unpair first)
Hi there. The steps you describe did not fix my Ionic when it had this problem. It had to be replaced.
12-06-2017 10:11
12-06-2017 10:11
Replaced? Setup go okay with your replacement device?
I currently have the Red X and a case open with support. Waiting to hear back.
12-06-2017 10:20
12-06-2017 10:20
@ebr206 wrote:Replaced? Setup go okay with your replacement device?
Yes. I had to send my Ionic to San Francisco and the replacement device came from the Netherlands. I just had to go through all the different options with support and then they gave in and told me to send it back. I had a DHL label emailed to me.
It looks like some people can recover from the red X, but others can't... It was certainly trying to pair and the error looked like it was the Fitbit app rather than the Ionic, so perhaps it is something which can be fixed by updating the app (eventually).
01-09-2018 20:45
01-09-2018 20:45
The Besen reply worked. Got rid of the dreaded red cross in the three steps. But as in most suggestions there are often inbetween steps.
1. Delete the ionic in the app - Go to the computer fitbit app, click on ionic. Lower right corner click Remove Iconic. I also removed my Charge HR.
2. Remove the ionic in the bluetooth profile - Windows 10 go to Settings/Devices/Bluetooth & other devices. Click on Ionic and then click on Remove Device.
3. Install the ionic in the app again - Return to the Fitbit App. Install new device Ionic.
I still can't insert my Starbucks number into the app.
