Last night, the heartrate graph in the android app jumped from 02:00 to 04:00, causing the graph to be 1 hour in the future. It is a nice feature to predict heartrates, but this looks like a daylightsavings bug. Also the sleep graph has a time problem.
B.t.w Ionic with 27.32.4.19 firmware working without problems and displaying the correct time. Android app is also up to date.
Is the time on your device correct or not?
If not change the timezone to something different. Sync it. Go back and change to the correct one and sync again.
This will not fix the graph problem though. I dont think there is anyway to do that
Wendy | CA | Moto G6 Android
Best AnswerYeah I've also got a gap in my heart rate data and sleep data from last night.
I'm not sure anything can be done, as technically that hour doesn't exist as far as the time stamps on the fitbit are concerned. It only happens twice a year for us, so I guess it's something we can live with.
Best AnswerYes you are right, the gap is two hours. Mine is from 00:55 - 03:00.
