01-22-2018 03:30
01-22-2018 03:30
Is it possible to define / create own activities like sauna, gymnastic,... ?
Best Answer01-22-2018 06:55
01-22-2018 06:55
Hi @michel777,
Yes, on the web dashboard at fitbit.com, under log > activities.
FYI, I wouldn't bring the tracker in a sauna. The high heat is pretty hard on the electronics, and Fitbit doesn't recommend using one in there.
01-22-2018 06:55
01-22-2018 06:55
Hi @michel777,
01-22-2018 09:23
01-22-2018 09:23
Does such selfdefined activity appear on the device ? Can the activity started end stopped on the device ?
Best Answer01-22-2018 09:28 - edited 01-22-2018 09:32
No, the ones on the watch are limited to the ones Fitbit provides.
1. Create the exercise category on the web dashboard.
2. On the Ionic, start a Workout activity manually. (You may have to load Workout mode if it doesn't appear)
3. Then after the activity is over, stop it on the watch and go to the web dashboard and change the name to the category you created.
The Workout mode allows you to rename it to other categories.
01-22-2018 09:34
01-22-2018 09:34
Thanks a lot ! It is possible to track more activities on my own ? I need sauna, gymnastic?
Best Answer01-22-2018 09:36 - edited 01-22-2018 09:38
