@IonicOwner1 wrote:
My fitbit ionic display will not turn on when i raise it, this started after the update. How do i fix this ?
Try to press and hold the left button. Tap screen wake to auto. It may have somehow got set to manual.
Vote if this helps you at all and Vote if this is a solution to your issue [Current Leader in Ionic Forum with 15 Solutions + Thumbs Up 92]
Really there is no need to suffer in Frustration - simply call Tech Support at 877-623-4997 and get your Ionic replaced right now while you can
Many have followed this straightforward advice and now have a replacement Ionic - we all should have “zero tolerance” for any defective Ionic
