01-19-2019 12:07
01-19-2019 12:07
My ionic battery goes flat in 10 hrs I have reset it done a factory reset stripped all apps off as per your help but it's not helped. Whether I do 1000k steps in a day or 20000 it runs out of battery will loose 10% in 1hr after being charged. Previously would last 4 days
Best Answer01-19-2019 12:12
01-19-2019 12:12
@Goose1975 wrote:My ionic battery goes flat in 10 hrs I have reset it done a factory reset stripped all apps off as per your help but it's not helped. Whether I do 1000k steps in a day or 20000 it runs out of battery will loose 10% in 1hr after being charged. Previously would last 4 days
Yeah this has been reported widely. Contact Tech Support and see if they can fix it. Normally if deemed defective they will replace your Ionic. Try that.
