01-17-2021 05:50
01-17-2021 05:50
I would like to edit the distance when running on an treadmill. I use the ionics treadmill mode but the distance is way of. On a 10k run it is of by 2.2k shorter.
01-17-2021 05:59
01-17-2021 05:59
The recorded exercise cannot be edited, but you can change your profile Stride Length to adjust the calculated distance. In the Treadmill mode the distance is a calculated number based on the number of steps by the stride length.
Best Answer01-17-2021 06:06
01-17-2021 06:06
Yes I know but. It would be a great and simple feature to be able to edit the distance after running on a treadmill.
A feature we would love to se from what i can se in all the community posts.
01-17-2021 06:19
01-17-2021 06:19
That is not likely to happen any time soon, as it would totally destroy the ability to have honest challenges. If users could edit their steps or distances, the challenges dashboard would change on the fly.
Best Answer01-17-2021 06:28
01-17-2021 06:28
But surely it's more important to have accurate distanceses. The challenges är secundary in My opinion. The greatest opponent is yourself 😁
02-19-2021 05:33
02-19-2021 05:33
I have been searching the same question. I use MapMyRun as my primary tracker and have to manually log any treadmill runs (which are more frequent in the winter). Tracking distance on treadmills is really inaccurate anyway and a manual entry on the Fitbit app should be allowed. Not sure why this has not changed.
