03-06-2018 11:25
03-06-2018 11:25
I have a problem with setting up the Wallet. The guidance provide in one of the other questions did not work
1) Removed the Wallet app (wallet is not on Ionic)
2) Reinstall wallet app (wallet is on Ionic Again)
3) Push the "Device Lock"
4) Box "setting up your wallet"
5) Error message:
Error Registering Ionic with Fitbit Wallet
javax.net,ssl.SSLProtocolExceptio
n: SSL handshake aborted :
ssl=xxxxxxx Failure is SSL library, usaully a protocol error
error:1407742E..SL
What should I do ?
03-08-2018 16:33
03-08-2018 16:33
Welcome to the Community @EddyBin! Thanks for the details you've shared about the error message you're getting. I would like you to try the following troubleshoot:
- Restart Bluetooth
- Force sync
- Try to set up again
If after this you're still getting issues, please provide me with your device model and OS version.
Hope this helps!
05-13-2020 14:47
05-13-2020 14:47
I have the exact same error and Im using a Note 5 SM-920V and Android version 7.0
