Have an Cross Trainer for bad weather days. What is the best exercise setting to use when training on a cross trainer?
Best AnswerThankyou so much but i don't seem to be able to get my Ionic to update the change. It keeps saying Bluetooth and im using wi fi
Best AnswerThe best setting to use would be the Elliptical exercise shortcut. If you haven't already done so you may have to remove one of the other exercises before you can add Elliptical. You can only have a maximum of 7 shortcuts on the device at any one time. The following link will have instructions on how to do this.
Best AnswerYou will need to sync your Ionic with your phone or Windows 10 device via Bluetooth for the changes to apply.
WiFi on the Ionic is only used for OS updates and app updates, everything else uses Bluetooth.
Best AnswerWow had a dongle form a previous fitbit - worked a treat - all up to date. Thank you SO much for your help. SO grateful
