How can I add more exercise trackers to my ionic, for example stair climbing we gym, elliptical machine, zumba, cycling with stationary bike or walking. I want to log it but there is only run, bike, swim, treadmill, weights, interval trainer, and workout. I want to remove some of those and add what I do. I've looked in app and I tried to look in app store but all I found was fitbit coach.
Thanks in advance .
@Dorissin the app Iconic device settings use Exercise Shortcuts to remove exercises you don't need/want, and add the ones you do - you can have up to 7 Exercise Shortcuts. You can also change the order of the Exercise Shortcuts by dragging them up or down in the list. After you have made changes, make sure you sync your tracker so the changes are uploaded to it.
@DorissI use Workout and then rename it.. An example I use my Trackers in multi mode concurrently with the Ionic and the One.. When I shop in a mall I set Workout and then I can do a comparison to the One for steps and I rename it to Shopping etc. Others are using that option for Walk and rename it to the name of the walk the took.
The only catch is you need to ensure the names are in your PC under the list of activities because you will not be able to change then on your Phone or PC.. On the PC when you rename a Workout it will prompt you to create the Custom Activity if it's not in the Activity List.. On the phone it prompts for a name and if that's not in your PC you cannot rename the Workout from the phone.
@Doriss wrote:How can I add more exercise trackers to my ionic, for example stair climbing we gym, elliptical machine, zumba, cycling with stationary bike or walking. I want to log it but there is only run, bike, swim, treadmill, weights, interval trainer, and workout. I want to remove some of those and add what I do. I've looked in app and I tried to look in app store but all I found was fitbit coach.
Thanks in advance .
Thank you so much, I was able to do it when I figured out I had to delete the ones I didn't use and add new one Yaaaaay thank you!
