FitBit stops functioning while sleeping for an hour or so at a time - happens multiple times during - what is the cause or fix - thank you!
Best AnswerI don't know what the cause is, but you might want to consider doing a reset on your device. Just hold down the bottom right and left buttons for 10 seconds. When the Fitbit logo appears, you've successfully restarted your tracker.
one cruise ship at a time!I don't know what the cause is, but you might want to consider doing a reset on your device. Just hold down the bottom right and left buttons for 10 seconds. When the Fitbit logo appears, you've successfully restarted your tracker.
one cruise ship at a time!Restart the device every day? My much cheaper Garmin device did a much better job registering sleep. According to Ionic, I do sleep less than two hour every night. That is completely bonkers. And I did change settings to sensitive. Ionic are unable to register sleep on me. Donno why and it frustrates me.
