01-04-2018 20:35
01-04-2018 20:35
I’ve read lots on the Fitbit not working with the iPhone X but nothing has been done about getting it sorted. I’ve ‘forgotten device’ on my old phone and tried to sync it up with my Fitbit, deleted the app and reinstalled the app a few times and it’s still not working.
I’ve had my Fitbit ionic for while and I want to send it back as the main reason for using it is to get Vitality points. I’ve ended up re-syncing my Fitbit to my old phone (which I want to sell but I’ve left it so my Fitbit app gets updated for Vitality points). Its been months since the iPhone X was released and I’m done waiting, I want to switch to a device which works so I want a refund on my Fitbit ionic but there’s no way I can return it because I don’t have the packaging. Fitbit needs to refund their customers for the poor service and put on the website clearly Fitbit devices won’t work on the iPhone X
01-04-2018 21:48
01-04-2018 21:48
I'm so glad I saw your post before purchasing! I have the iPhone X as well.
Best Answer01-05-2018 02:14
01-05-2018 02:14
I have an iPhone X, and it works just fine.
01-05-2018 06:08
01-16-2018 00:09
01-16-2018 00:09
Mine worked fine for a few days then I had to reset for it to sync. It then worked for a couple of days but now won’t sunc at all. It’s so frustrating!!
01-16-2018 00:11
01-16-2018 00:11
Best Answer01-16-2018 04:37
01-16-2018 04:37
According to the compatible devices page it should work.
https://www.fitbit.com/devices
Have you updated your phone to the latest IOS? Needs 11 or later. Apples power saving system can often lead to sync issues with 3rd party devices, that's about all I can suggest at the moment sorry if it doesn't help, happy if it does 😉
Best Answer01-16-2018 04:51
01-16-2018 04:51
Best Answer01-26-2018 06:17
01-26-2018 06:17
Same here. Bought the X and Ionic. I spoke to Fitbit support and they told me that Apple had not approved the updated version that would synch with Ionic. I am guessing Apple is taking their time since the Ionic competes with the Iwatch.
wrote:
Thanks for replying. I am updated - I did plug watch in to charge earlier ( it still had half battery) & reset it again. It’s now syncing so will see how it goes.
Sent from my iPhone
Best Answer03-19-2018 13:42
03-19-2018 13:42
What worked for me was restarting the Ionic after the app did not pick it up and disconnecting all BT connections from control center at the same time. Immediately after re-enabling BT connection from control center the iPhone X picked it up through the app and started updating the Ionic. Remember that the software is just the same as any other iPhone (iOS11) and it should work fine, also the BT antenna is way better than past iPhones. A few other things that helped were me being connected to the wifi network and turned off all other BT devices close to me. For past Fitbits what used to work was turning BT off from your phone, wifi antenna off from your phone, force closing the app, restarting the tracker + phone at the same time and performing the pairing process again (which did not erase your data).
Hope this helps !
03-20-2018 00:09
03-20-2018 00:09
Best Answer03-24-2018 18:44
03-24-2018 18:44
My app get stuck in a loop where the app asks for the BT authentication code from the Ionic. I’ve tried to restart Ionic, restart BT, restart and delete app.
Getting really frustrated with this Ionic, and looking toward an Apple Warchnif this does fix soon. Was on customer service for over an hour trying to figure it out. The fix was to not use iPhone X. I’m not going to use an old phone to only support FitBit.
Please fix, or I’m going to the competitor device.
Best Answer05-07-2018 20:56
05-07-2018 20:56
Yes this worked thank you for the advice 🙂
