06-10-2019
23:17
09:30
YojanaFitbit
06-10-2019
23:17
09:30
YojanaFitbit
My Ionic was fully charged yesterday, and has turned black during the night. Wont start again
Best Answer06-11-2019 09:28
06-11-2019 09:28
Nice to see you on the Community Forums again @Umohus. Thanks for reaching out.
I'd suggest to clean the contacts of your Ionic. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this may damage the plating and result in corrosion.
Please try to restart your Ionic again. We recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker. Did you have issues before with the charging cable?
Please take a look of these recommendations to charge your Fitbit too.
Let's give it a try and please keep me posted.
06-11-2019 09:28
