07-05-2020
12:53
16:52
SilviaFitbit
07-05-2020
12:53
16:52
SilviaFitbit
My ionic died this morning. I've had it on the charger for 6 hours, switched outlets and chargers and it will not power on. I've tried the factory reset, I've tried all three buttons, I've tried to sync it, I've tried the left and bottom button, I've cleaned the sensors, absolutely nothing works. I don't think the battery was even low enough for it to just die. I just bought 10 bands for this thing last week and now I can't even use it bc it won't turn on. I haven't even had it a year yet.
07-08-2020 08:39
07-08-2020 08:39
07-08-2020 09:17
07-08-2020 09:17
Oh no @IronMike2 I thought you were back up and running again! Fingers crossed they sort it for you! I was at such a loss without mine. I have been a traitor and moved to another brand I'm not allowed to name. Will see how long this one lasts. I hope you get your watch sorted.
07-08-2020 09:40
07-08-2020 09:40
07-08-2020 14:48
07-08-2020 14:48
Having the exact same problem. I don’t see anyone from Fitbit addressing those problem. Is this made in China?
07-08-2020 15:34
07-08-2020 15:34
Yes, this happened to me as well just now. I've had mine for just less than 2 years. Was working this morning, have not had battery problems, and now it's totally unresponsive. Was nearly full charged too. Black screen. Followed reset instructions multiple times and nothing. Not seeing the green light from the back sensor either.
What's going on here?
07-08-2020 15:55
07-08-2020 15:55
07-08-2020 16:53
07-08-2020 16:53
Use their help options. Your watch is less than 12 months old and they will replace it.
07-08-2020 16:55
07-08-2020 16:55
07-09-2020 03:58
07-09-2020 03:58
I held all 3 buttons for what seemed long time, maybe 20ish secs? 0% came up but didn't appear to be charging but in the hail mary approach I left it on the charger again rest of the early night and thru to morning...a good 12 hours and it was on, charged 100%...2 days later seems to be working fine no issues thus far...I know a few posted may have had an addl issue with seal compromised...I didn't have that so hoping it is resolved... had my ionic since Nov 2017 so far so good with this one exception!! Good luck all!
07-09-2020 04:46
07-09-2020 04:46
DITTO............I've had it since March 2018. Last night, it went black screen and nothing has worked. I've tried different cables, different outlets, PC plugin, Reboot attempts...........its DOA, which is disappointing. There are 3rd party places that can change the battery, and at this point the warranty is gone anyway, so I may take the plunge if the cost makes sense............
07-09-2020 05:07
07-09-2020 05:07
I had the same issue with my IONIC after about 5 months or so. I suggest you open up a chat at Fitbit.com and start a replacement request. If it is under a year, they will replace the watch for free.
07-09-2020 05:38
07-09-2020 05:38
07-09-2020 07:06
07-09-2020 07:06
Follow up on my post. So...after trying multiple times to restart it or charge it or get it do respond, I put it down until last evening. On a whim, I plugged it in and...got the green diamond logo and then it just started to work again. It was like 12% charged or something like that. The clock was about off 8 hours until I synced it. Got up this morning and it's back to normal?
Given that electronic things seldom just fix themselves, I'm still wondering what's going on. Is this a sign that the battery is going? Don't know. Ideas?
07-09-2020 13:27
07-09-2020 13:27
Pushing the back button and lower right button for 15 minutes worked like a charm. I had been charging it but it appeared totally dead. Originally, I let the battery go completely dead.
07-09-2020 13:27
07-09-2020 13:27
07-09-2020 15:18
07-09-2020 15:18
07-09-2020 17:08
07-09-2020 17:08
Mine did the same exact thing months ago. Has never turned back on. Happened to two Fitbit Versas that I bought as gifts for people. So, 3 Fitbits and hundreds of dollars later and all of us have dead Fitbits and Fitbit has horrible customer service. Even though this is an issue it seems because of the last upgrade, they won’t do anything except give you money off of a new one. Done with Fitbit.
07-09-2020 23:47
07-09-2020 23:47
15 minutes?!
07-10-2020 05:58
07-10-2020 05:58
Following up my post about my dead Ionic..........left it charging at work for the morning yesterday. Out of sheer curiosity, I went to restart it and BINGO..........startup logo, then phone screen..with 100% battery! Interestingly, it didn't boot up on its own. One of my issues was that I had push notifications disabled on my iPhone settings for some reason, so unless I was looking at the battery level on the watch, I didn't know it was at 0%. Now i'll get heads up alerts to avoid this panic attack in the future...........
07-10-2020 08:49
07-10-2020 08:49
