10-17-2018
08:17
10:34
AndreaFitbit
10-17-2018
08:17
10:34
AndreaFitbit
Hello, My fitbit Ionic worked great for the first 8 months now sometimes it continuously counts steps.Also the battery drains with in 3 to 4 hours. Is this issue common or could it just be a faulty Ionic?
Welcome to the forums!
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help Contact Support.
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
10-19-2018
10:55
08:08
10-19-2018
10:55
08:08
It's nice to see you here @joew2444. I'll be glad to assist you with your Ionic's battery drain issue.
I recommend to change your charging power source and to follow the steps from help article Can I improve my Fitbit device's battery life?
When does your device continuously count steps? Is that a recurrent issue, does it happen at some time of the day or sporadically? Are you doing some activity when this happens?
Thank you for your help @WendyB!
I'll be waiting for your response.
13:18
08:07
10-19-2018
13:18
08:07
Welcome to the forums @joe2444. I'll be glad to assist you with your Fitbit step count inquiry.
In order to assist you could you please tell me if there's a surface wit vibrations where you charge your device.
07:46
08:07
10-23-2018
07:46
08:07
Thanks for getting back to us @joe2444. I apologize for the delay on my response and will be glad to continue assisting you.
I've created a case on your behalf and a Customer Support representative will assist. You can check your email.
Keep on visiting the forums.
