05-01-2018
18:12
07:22
05-01-2018
18:12
07:22
Will not sync over Bluetooth even when both watch and phone are reset. Phone =Android running 6.1.
Best Answer05-03-2018 07:31 - edited 05-03-2018 07:32
Welcome to the Fitbit Community @PeaPodMan! Thanks for already troubleshooting this syncing issue between your phone and your Fitbit Ionic, nice way to go!
While reading your post, my first thought is that your Ionic might be no longer paired to your Fitbit account and that's why it's not syncing or connecting to your phone's Bluetooth. In order to solve this, please go to the Bluetooth settings on your phone and remove the tracker. In the list of Bluetooth devices you'll see the Ionic and next to it, this symbol "!". Hit the symbol and it will take you to the next step, once you're there select the option that says "Forget this device".
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device. ![]()
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below, if you're using the Fitbit app for iOS, Android, or Windows 10:
If you're still unable to set up, try these troubleshooting steps:
Give this a go and let me know the outcome!
Best Answer05-03-2018 11:31
05-03-2018 11:31
These are nice suggestions, but it is a reoccuring problem.
I had gone through all steps. It works for a few hours, maybe a day, and then stuck again.
05-03-2018 14:07
05-03-2018 14:07
This solution is not consistent, sometimes it works and the majority of the time it doesn't. I have to do this numerous times everyday just to sync my Ionic once to my iPhone 7+. The issue is the Ionic, Fitbit knows this and still won't fix the issue
