05-03-2018
07:42
10:07
05-03-2018
07:42
10:07
Like many others my watch won’t sync and calories burned are way over what they should be. Is there a time scale to when these issues will be fixed or is just going to be more silence from Fitbit? Spent a lot of money on this watch and would like to know that Fitbit have recognised the problems are there and they are working to fix them rather than the silence.
05-04-2018 10:13
05-04-2018 10:13
Hey there @Stubhoy67, thanks for stopping by! Thank you for the thorough feedback for the Fitbit devices. This has not gone unnoticed and be sure that I will pass this along.
We don't want to create frustration in our customers. Fitbit has been designed to provide motivation and help you to reach your daily goals to success. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback.
Syncing difficulty is usually caused by a missing requirement. Verify each requirement before moving on to the troubleshooting steps.
If your device still won't sync, try these steps:
Give this a go and let me know how it goes!
05-04-2018 10:18
05-04-2018 10:18
I accepted this solution by mistake, please take it off if you can. I have done every step you mentioned 4/5 times and am sick to the back teeth of it. It’s not only me that is having issues going with the posts on here.
05-04-2018 10:20
05-04-2018 10:20
Why did you change my post header?
