10-05-2021
07:52
11:39
CindyMFitbit
10-05-2021
07:52
11:39
CindyMFitbit
Hello!
I'd using my Fitbit ionic with my iphone since 2019 without any issue. I lost my phone last month. I decided to connect ionic to desktop PC instead (windows 10 64x)
I bought universal bluetooth 5.0 dongle (with LE enumerator).
I'm trying to connect it with bluetooth but it is not showing up in available devices.
I tried to connect headphones and other devices (to see if the dongle is faulty), they showed up immediately and connected fine.
Help please!!!
Best Answer10-05-2021 11:52
10-05-2021 11:52
Welcome to the Community Forums @salmanzaidi.
Thanks for the details shared on your post and for the troubleshooting tried prior posting. I'd recommend trying the following:
Hope this helps.
Best Answer10-12-2021 02:27
10-12-2021 02:27
Thank you for your reply.
I tried it but the connectivity problem still persists.
Settings>Bluetooth>Restore Music Controls (Pair your phone if Music Controls are not working)- I changed it to pair.
Ionic (Classic) was visible in Bluetooth devices are paired immediately.
But this didnt solve the sync issue.
I'm using csr8510 a10 Bluetooth chipset as my PC bluetooth.
Please advise
Best Answer10-12-2021 11:27
10-12-2021 11:27
@salmanzaidi Thanks for your response.
Thanks for trying the suggested instructions. In order to sync you need to use the Fitbit app and sometimes even though it is not connected on Bluetooth, it is able to find the connection within the Fitbit app, so please confirm, are you getting an error message when you try sync? In the meantime, please review the following requirements to sync with the computer:
Catch you later.
