12-04-2018 16:43
12-04-2018 16:43
I recently upgraded to the fitbit ionic and I am really really frustrated. I am sick and tired of having to restart my phone, force stop this, restart that!!!! When are you going to fix this issue that is clearly a problem for everybody????
12-04-2018 18:09
12-04-2018 18:09
Im with you. Mine wont do any sync of any sort now. Even after all the restarts and unpairings.
12-04-2018 19:06
12-04-2018 19:06
May I ask what type of phone you guys are having problems with?
Are they on the compatable list?
12-04-2018 19:18
12-04-2018 19:18
Samsung Galaxy S8 which is on the compatibility list.
12-04-2018 19:35
12-04-2018 19:35
Even I am not able to sync with my Google pixel 2 phone .
12-04-2018 20:24
12-04-2018 20:24
Welcome @lsuresh494 are you having a sync issue, since this is your first post I'm not sure what the issue is.
If so let's go to the phones settings, apps, Fitbit, storage, Clear Cache
12-05-2018 12:04
12-05-2018 12:04
I have an LG G6. Which is not on the list for some reason. Not like its an ancient phone. Only had it for a year, on top of that, it runs current android software.
12-05-2018 13:33
12-05-2018 13:33
Samsung Note 8. I have to restart bluetooth, after 3 or 4 tries it will finally sync. It is very frustrating.
12-05-2018 14:11
12-05-2018 14:11
Does fitbit provide any directions on how to use adb and logcat and grab the logs from these failing devices? I'd think it would have an obvious exception that would give some insight. Having people do various random things seems rather unscientific to solve the problem.
I'm only on day 3 with my Ionic and haven't had any sync issues. I'm on Pixel XL v1, Android v9 on Project Fi (now Google Fi). I just upgraded from a Charge 2 HR that had zero issues too. I've been on fitbits since the Flex so it has been a long time now.
Good luck you guys. I can understand the frustration. But there has to be a way to find the logs and find out what is failing. I would also try airport mode on then off to see if that resets anything in the phone with bluetooth.
12-05-2018 16:17
12-05-2018 16:17
I did delete the device in the mobile's Fitbit app and did pair like a new device and then it succeeded. Fitbit should fix these issues. It's bad that high priced Device behaves like this.
12-05-2018 16:20
12-05-2018 16:20
Issue was it's just not syncing. I did clear the cache and un install the app and re install and nothing worked. So I deleted the device and in the app and paired it again and finally it worked after that. It's a stability issue you guys should look to fix it.
12-05-2018 21:36
12-05-2018 21:36
My ionic shows zeros for steps, Calories, heart rate, activity, and battery. I restarted several times but no change. It does show data in the app. I am using the awesome clock face which I paid for. Also my ionic no longer gets texts or notifies of phone calls. Using iPhone 6. Very frustrating.
