03-25-2020 23:49
03-25-2020 23:49
Since a few days my Fitbit only registers basic sleep stages. It also stops registering sleep when I wake up at night and go to the bathroom. It doe not register any sleep after that. I have my Fitbit Ionic for many years now and this never happened. I have restarted my device already without effect. I have the latest version on the app and watch. It registers my heartbeat so that is not the issue. Could this be related to the recent update?
Best Answer03-27-2020 02:58
03-27-2020 02:58
I am having the same problem. My 2 years old Ionic started to register more and more simple sleep stages. Than 2 weeks ago it would not sync anymore, and after a reboot it looped continuously in start-up. So a factory reset was needed to get my Ioinic going again. As surprise the sleep stages were also recorded correctly again. So I am thinking now that this was an issue with the watch and not something else.
Also now again for 3 nights in a row only simple sleep stages.
I have rebooted my watch just now and will see if that will change anything. If not I will do again a complete reset to see it that solves the issue.
I also wonder if anyone has seen something similar.
Best Answer03-28-2020 00:47
03-28-2020 00:47
Did you loose any data with the factory reset on the app?
if not I will try the same. My watch is about 2,5 years now.
Best Answer03-29-2020 06:08
03-29-2020 06:08
If you are able to sync your watch , you will not loose data.
After I restarted my watch , I have now again 2 days of detailed sleep.
Best Answer03-29-2020 22:21
03-29-2020 22:21
Well, I have reset my watch to factory settings and still no detailed sleep data. It registers 4 hours of sleep on average for an entire night.
All the rest is functioning on my watch 😞
Best Answer04-08-2020 03:04
04-08-2020 03:04
Hi Rose, I would not know a solution for that.
My watch again logged 4 days in a row only simple sleep. A restart yesterday did not help.
Again I decided to reset my watch completely and start form factory defaults.
Wondering if this will change anything.
Best Answer04-10-2020 10:54
04-10-2020 10:54
I did a factory reset and no change. Hopefully they can get this fixed. If I have to buy a new watch I will be going away from Fitbit all together
Best Answer04-10-2020 12:05
04-10-2020 12:05
I have restarted the watch and did a factory reset. It did not solve the problem. About 2 days later it started to register sleep again. Not sure what triggered it.
I did ensure that my phone had all recent updates as well before the factory reset.
04-10-2020 12:05
