Up until about 2 months ago my fitbit Ionic worked like a dream. Kept time perfectly. Synced whenever I woke her up and tracked my swimming, sleep, everything. Now its behaviour has become haphazard at best. I have
Here are the deets.
Fitbit Ionic Software version - 27.331.30
Set on constant bluetooth connection
Smartphone deets:
HTC U11 plus
Android Version 8.00
Software information
1.24.709.994
Kernal version 4.4.78 perf-g3347e2c
And@AABM#1
SMP-PREEMPT
Baseband verion
8998-002772-1712201227
Build number 1.24.709.994.9.0
Can you help. Because I used to love Fitty and now I eye her suspiciously. Knowing she is not recording my metrics properly.
Best AnswerThe device you are trying to sync is not a supported device?
You can find a list of compatible devices here and here.
I suspect an app date may have broke what wasn't supposed to work anyway. Another update could restore function but there is no guarantee.
One thing you can try is to install an older version of the app from when it did work. You can find older versions here, though Fitbit does not recommend it.
Best AnswerThe failures took place before the last update. There was NO update on the phone or the fitbit that resulted in the change in device behaviour. And you CANNOT discount that the device worked perfectly for a year.
This answer is not helpful.
