I wouldn't remove the device as this can cause further problems.
Instead I would try restarting your phone and then restarting your fitbit using this procedure:
Give this a few tries as it doesn't always work. If it still won't sync after that then there are some more ideas to try in this help file: http://help.fitbit.com/articles/en_US/Help_article/1866
Sorry I don't understand the question.
Settings / About / Shutdown.
I had the same problems but nothing worked for me so I took mine back to the shop and replaced it with a Garmin.
Good Luck
