08-28-2019 20:43
08-28-2019 20:43
It's been days since my Fitbit has synced. I've checked the bluetooth connection, battery is full firmware version is 27.33.1.30 - any suggestions? Thanks!
Best Answer08-28-2019 23:22
08-28-2019 23:22
The usual things to try when you get syncing issues are:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
