05-06-2020 07:53
05-06-2020 07:53
Can’t get my iconic to change.Have been advised to clean connections with rubbing alcohol but have no idea what this is!
Best Answer05-06-2020 08:03
05-06-2020 08:03
Hi @Malkie69 rubbing alcohol is pretty common. Here is a picture of Walmart's brand of it. They come in different strengths and usually cost under $2. If you have a dollar store, you might find a bottle there.
Best Answer05-06-2020 08:07
05-06-2020 08:07
Best Answer05-06-2020 08:13
05-06-2020 08:13
According to Wikipedia: "Rubbing alcohol is either isopropyl alcohol or ethanol based liquids, or the comparable British Pharmacopoeia (BP) defined surgical spirit, with isopropyl alcohol products being the most widely available. ... They are liquids used primarily as a topical antiseptic."
Best Answer05-06-2020 08:16
05-06-2020 08:16
