Ok. So we know that after your exercise may it be walking or running when you use the exercise on your Ionic it will be logged on your phone when you sync it. Then you will see your GPS map with your stats (pace, hr, calories burned, etc.) and the track itself on the map (tracked you covered with your run).
Ok my wife is using her iOS and was able to share the GPS map itself. For iOS devices there is an option to share the map. For android there's none.
Is this a known issue or nobody encountered this before? I hope that someone from Fitbit can help me out.
Thanks much!
I didn't realise you could share the map on iOS, that's very interesting, i will have a look a that on my iPad.
I have noticed on my android phone that attempting to share a run only shares some stats and not the map, would be goo dto have this option - map and stats!
