08-28-2019 06:33
08-28-2019 06:33
My ionic just wont show gps maps despite location always turn on. Ive tried log out and login, update my software. Is there anything else that i can do?
Thanks
Best Answer08-28-2019 14:25
08-28-2019 14:25
@Qawiy, I assume you are referring to the Fitbit app that is not showing the maps, not the Ionic itself, correct? Which app are you using, and what is the version number of it?
Best Answer08-28-2019 16:36
08-28-2019 16:36
Yes correct on my apps n dashboard. It just wont show. Previous run maps are available in the apps. Im using FitBit 3.4
