12-17-2019
16:27
05:38
YojanaFitbit
12-17-2019
16:27
05:38
YojanaFitbit
Same issue here Me...
Bricked original Ionic due to failed update.
”New” Ionic sent as original was still under warranty, the “new” ones heart rate sensor doesn’t work.
Refund time as it appears there are defects with the product that render it unfit for the purpose intended, I.e. not of merchantable quality.
Best Answer12-18-2019 05:03
12-18-2019 05:03
Hi @Semmyconcious
After the update, my Heartrate sensor does not work either, the BATTERY from 100% drains in 5 hours.
At the moment is as useful as a brick, wont even make a good doorstop .
12-18-2019 07:06
12-18-2019 07:06
Yup, so for CLARITY,
Original Ionic bricked whilst updating firmware.
Brand new replacement Ionic.
Updated to latest firmware upon removal from the box.
Update went fine.
Issues are:-
1. No Heart Rate Sensor
2. No sleep tracking
3. Battery went from 100% to 40% in under 24hrs
For admin/moderator - I am screenshotting these posts as they seem to be dissapearing
Best Answer12-18-2019 12:52
12-18-2019 12:52
Hah, “New” case opened so they can look into the issue....
Sounds like a delaying tactic to me.
The issue is either a bugged firmware release or a faulty item (bearing in mind this is a “new” replacement Ionic.
Best Answer12-18-2019 18:45
12-18-2019 18:45
And another round of trying resets of varying flavours to no avail....
Best Answer12-19-2019 07:42
12-19-2019 07:42
And another free replacement...
To be honest should this be a bust I will be placing a case in small claims court as they have denied a refund (good luck with that Fitbit, as under U.K. law if the goods are not fit for the purpose intended I will win with costs).
