Heartrate sensor issue:
I am on holiday. I am switching off my Ionic every night to conserve battery power. Every morning I switch it on again, and everything seems to be working AOK. This morning, however, I noticed I cannot get the heartrate sensor to work:
... I just cannot get the heartrate feature to work.
Can anyone help at all?
Best Answeri turn my watch off as i only use for activities, My ionic has often been off for 3-4 days and once for 3 weeks when abroad working. I have also experienced this issue but I dont think its a fault, sometimes going to the settings and turning heart monitor off and back on has cured it as has turn the watch off again and back on, ive tried a reset to no avail. I would suggest if in settings, its already turned on and not working , cycle through off and back on a couple of times
MAke sure in your settings that it still has a check mark in it
Turning it off at night really doesn't conserve battery power. It could be why you are having this problem now as well
Wendy | CA | Moto G6 Android
Settings where? On my watch, in settings, I do have the heart rate option set to 'on'.
Best Answerit does conserve battery power. I use my charge 2 as a normal watch and my ionic only for running or cycling. Ive gone a month or more between charges with this type of use.
