Today, my Ionic screen went blank and an hour or so after trying to hard reset it, it displayed a triangle with an exclamation mark. When I tried to reset it again, it went blank. What can I do? What does it mean?
It's great to have you here @D4getmenot2! I appreciate the reset you performed in order to fix the blank screen you got.
The triangle an exclamation mark, usually means that the firmware update didn't finish correctly. However, in your case doesn't seem like you were doing this procedure. I would like you to confirm you followed these steps to restart it:
I'll be around if you need anything else.
Hey there @D4getmenot2! Thank you for sharing the solution that you got. I'm glad to hear that you got a replacement.
Don't hesitate to get back if you have any other questions! ![]()
