10-01-2017
04:25
19:21
EdsonFitbit
10-01-2017
04:25
19:21
EdsonFitbit
Dear all,
I can not find the WiFi settings on the Fitbit application on My Mac. I thus can not activate WiFi connection at all. I do not find the General settings under Ionic menu. Could you please help me out?
Many thanks.
Ionic has minimized a lot of the desktop app settings (perhaps to make room for coming App settings).
A couple examples of "mobile only" control are the clock faces feature, and, as you have discovered, the wifi feature, appearing exclusively on your mobile @Oluskayacan
On your mobile, click the gray'd index card in the upper right corner, touch picture of your ionic, scroll up to wifi settings, to add one you know the password to touch "add network".
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
