03-24-2019 09:29
03-24-2019 09:29
How do I track distance when I am in a spin class?
Best Answer03-24-2019 12:57
03-24-2019 12:57
@BandQ your description of the problem reminds me of the XY problem. Basically, we were not fully aware of what your problem really is and when we try to give you any solution then you give important details 😄 That's just small digression. Well, the distance measured by steps you obtaining during spinning will never match the spinning machine. Spinning is not step-based exercise and even if you get steps, the stride ( probably the walking stride ) won't guarantee the accurate distance computation. However, with a little bit of simple math, you could actually manually calibrate the stride. It's just a crazy idea but:
1) start exercise and stop when spinning machine shows lets say 1km or 1mile.
2) see how many extra steps you registered during this lap.
3) divide 1km ( or mile ) by a number of steps.
4) manually adjust your stride in the app to the result you received.
5) Start exercise again and see if such calibration worked, if so remember that number and use it every time you use this spinning machine.
Of course, still, the Spinning exercise doesn't have distance but I believe you would get the distance added to the daily stats. Still, I guess workaround with "Bike" exercise is simpler 😄
03-24-2019 09:40
03-24-2019 09:40
Hi @BandQ Unfortunately it is not possible to track distance speed or cadence during spinning as the Ionic is not able to interface with any external sensors.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Best Answer03-24-2019 11:03
03-24-2019 11:03
@BandQ Agree with what @Tony.r said. You may log your spinning class manually after tracking it as spinning. The problem is that you cannot type distance in the Spinning exercise when logged manually. As a workaround, you may log "Bike" for which you can input the distance. If you log "Bike" use values for starting time, duration and calories the same as the ones tracked by "Spinning" ( both exercises will overlap in terms of timeframe ). Enter the distance from the stationary bike. Delete tracked "Spinning". Eventually, you will have non-GPS "Bike" in your activity log with distance matching the spinning machine and other details matching removed tracked "Spinning" activity. Bit of a chore but not sure what else you could do except this workaround.
03-24-2019 11:12
03-24-2019 11:12
Thanks for sharing your thoughts @SunsetRunner sounds like a work around even it its a bit long winded.
Tony | UK
03-24-2019 12:39
03-24-2019 12:39
03-24-2019 12:57
03-24-2019 13:01
03-24-2019 13:01
Best Answer10-07-2019 13:36
10-07-2019 13:36
I know it's not necessary to add distance to a spinning workout. My Flex 2 doesn't recognize some activities, so i have to add them manually. When I register Spinning manually, the app asks to add a distance. Otherwise I cannot add this spinning workout. This is definitely a bug in the Fitbit android app. So, which distance do I register? I had a 50 minute workout, incl. Warm-up and cooling down.
Best Answer10-07-2019 13:38
10-07-2019 13:38
My fitbit app asks to add distance. I don't want it to, but otherwise i cannot log the activity 😞
