09-27-2017 23:29 - last edited on 05-19-2023 17:30 by AndreaFitbit
I just got my new Fitbit Ionic and I was playing around with it. I enabled the PIN and now i'd like to disable it, but I cannot find a way to do that. I had gone through the wallet app, but did not enter a credit card. I tried uninstalling the wallet app, but I still don't see a way to remove/disable the PIN. I can reset the PIN, but not disable it. How can I disable it so I don't have to enter it in if I don't want/need payments?
Moderator edit: format.
10-27-2017 05:48
10-27-2017 05:48
Device Lock does not show up on my app.
10-30-2017 08:07
10-30-2017 08:07
Fitbit Ionic user, using Android Fitbit App. I too made the mistake of enabling the Wallet app, only to find I have to constantly unlock my Ionic with the horrible number keypad on the screen. There is no way to disable once enabled if you are using the Android Fitbit app. This is a fatal flaw for the Ionic. Ionic is my 4th fitbit, but this dumb flaw makes it the worst of the Fitbits I have owned.
11-11-2017 13:38
11-11-2017 13:38
hello. i was just having this same problem. android 8+. this is how i fixed it. setup pin lock screen for my phone itself (had just swipe unlock before). went back to app and clicked on pin. it will now let you go into that pin setting and disable! then went back and changed phone lock screen settings to whatever i had before
12-11-2017 00:54
12-11-2017 00:54
re-set the pin and then it gives you the option of turning it off
12-11-2017 18:37
12-11-2017 18:37
12-18-2017 07:07
12-18-2017 07:07
Yes using your phones pin number if you have one is the right way to access the pin lock unlock feature.
12-18-2017 18:41
12-18-2017 18:41
Set up a pin on your phone then open the fitbit app and go to the pin setting and it will give you the option to disable and then you can remove the phone pin
01-04-2018 13:34
01-04-2018 13:34
Yes. I was able to disable my PIN by entering in my android Phone's PIN; then selecting the option to "disable" the PIN; within the Fitbit app. I hope this helps.
01-11-2018 08:03
01-11-2018 08:03
Thank you! It worked. ❤
01-11-2018 08:27
01-11-2018 08:27
03-22-2018 13:07
03-22-2018 13:07
I just fixed mine - the problem is that the instructions at the beginning of this thread say to click on the wrong icon - click on the Ionic watch icon and then scroll down and you will find "disable"
03-22-2018 13:08
03-22-2018 13:08
click on the ionic watch icon and not the other icon - then you will find disable.
03-22-2018 13:09
03-22-2018 13:09
This solution is incorrect for the ionic - click on the Ionic watch icon and then you will find the disable button.
04-12-2018 15:19
04-12-2018 15:19
I was trying to disable from my laptop, Then went to mobile and turned it off with no problem..thanks
04-25-2018 09:45
04-25-2018 09:45
Disabling the device lock worked! THANK YOU!
05-14-2018 16:47
05-14-2018 16:47
Thank you!!! This was driving me crazy. I was able to set it only for the Wallet.
06-01-2018 02:51
06-01-2018 02:51
On the Fitbit app it says Device Lock "Enabled for Fitbit Pay" even though I don't use Fitbit Pay. When I try to remove it, it shows two options "enabled" or "disabled". I click disabled, and then there are two options, to either click the cross in the corner, or click "change PIN" - both of these cause the change to not be commited. i.e. it still says "enabled for fitbit pay". Is this a bug? How do I disable the PIN please?
06-03-2018 03:34
06-03-2018 03:34
When you get the message about setting up device security go put a pin or pattern on the device temporarily. It will then kick you back in to the fitbit app once that is completed and you will have the option to disable the lock there.
08-06-2018 17:33
08-06-2018 17:33
That did it, it was turned when wallet installed, uninstalled wallet,
And didn't realize one more step to disable lock screen as only for wallet which uninstalled equals never!
09-07-2018 06:31
09-07-2018 06:31
when i do that i get a notification that says, the operation couldn't be completed. (FBBluetoothEr-rorDomain error 8.) Anyone know how to fix this ????
