04-27-2018
09:55
07:20
MaginB
04-27-2018
09:55
07:20
MaginB
I would like to see the life of my battery on my IONIC.
As it is now I only get an email that says my battery is low.
Can I display the battery life on my IONIC?
Best Answer04-27-2018 10:01
04-27-2018 10:01
Yes if you switch up the screen you will see the % of battery
04-27-2018 10:05
04-27-2018 10:05
Thank you...such a simple answer, I should have known this a long time ago.
Cheers.
05-02-2018 07:24
05-02-2018 07:24
Hi there @Tegiro ana welcome aboard @yonok57!
Thanks for sharing your inquiry, as @Tegiro already explained you only need to swipe to the top and you'll be able to check the battery status on the upper right hand corner.
To know more about your Fitbit Ionic check out this great post.
Hope to see you posting more often!
07-28-2021 08:02
07-28-2021 08:02
Thanks for your answer!
07-28-2021 18:33
07-28-2021 18:33
Welcome to the Fitbit Community, @Caples_Kenny.
I am glad to hear the information shared in this thread was helpful. Thank you for your time and feedback. Let me invite you to visit our Health & Wellness board where you can share your experiences, make new friends and create your own topics.
Additionally, I recommend checking if your Fitbit device is updated to the latest version as updates come with new features and bug fixes: How do I update my Fitbit device?
Keep on visiting the forums!
