10-01-2018 09:10
10-01-2018 09:10
10-02-2018 12:20
10-02-2018 12:20
Sorry @CW112, I'm not aware of any know Pandora issues, I just checked the private known issue board.
I assume the ionic is setup for Pandora and the ionic is plugged in and able to connect to your wifi. You have checked the wifi settings in the Fitbit app/ionic/wifi setup to see if there is any message.
If everything looks good, then I would go to the ionic/music/Pandora click on the three dots and force the Pandora to sync. If the ionic is charging tap continue to get past the warnings
Best Answer10-02-2018 15:18
10-02-2018 15:18
Best Answer10-02-2018 21:19
10-02-2018 21:19
When you say that you do not have any stations @CW112, are you referring to the list if channels in the Fitbit app?Something like this?
