06-30-2018 09:00
06-30-2018 09:00
I have the Ionic, uploaded music to it and purchased Senso bluetooth earbuds. I have noticed that as I am running, the reception cuts out when my arm (that the Ionic is on) swings to the back. When I bring it back to the front, reception is fine. Can anyone who runs recommend alternative earbuds?
Best Answer06-30-2018 10:50
06-30-2018 10:50
I use inexpensive Anker Soundbuds which I purchased on Amazon. They're water resistant and have a very long battery life. They never cut out and the sound is good.
06-30-2018 10:50
Best Answer06-30-2018 22:16
06-30-2018 22:16
This probably has a lot to do with which arm, and where the earbuds BT antenna is.
Wothout people mentioning which arm the fitbit is on .Will not give use full days .
Best Answer07-09-2018 08:28
07-09-2018 08:28
Thank you. I ordered a pair of Anker Soundbuds on Amazon and they seem to work perfectly.
Best Answer07-09-2018 08:32
07-09-2018 08:32
Thank you. I wear the Ionic on my left arm, but I also tested wearing it on my right. It made no difference. I am thinking the antenna must be in the cord that connects the two earbuds, because if I wear the cord in front of my neck, sound cuts out when my left hand is behind my body. If I wear the cord in back, the sound cuts out when my left hand is in front. I purchased a pair of Anker SoundBuds recommended by another user and they are working great.
