02-19-2020 08:57
02-19-2020 08:57
I have a FitBit Iconic, it has worked for the past couple of years with only a couple of issues, but now it will not show charging and will not power on. I have cleaned the terminals I have tired different power outlets from wall outlets to USB ports on my computer, still nothing. Has anyone seen this issue and was there a resolution?
Best Answer02-19-2020 10:46
02-19-2020 10:46
I suspect your battery has died and they aren't replaceable.
Best Answer02-19-2020 11:29
02-19-2020 11:29
If the battery is dead the only choice is to thorough it away?
Best Answer02-19-2020 12:26
02-19-2020 12:26
Afraid it is as they are not replaceable. Have you tried holding down all 3 buttons for at least 20 seconds to see if that kicks the Ionic back into life?
Best Answer02-19-2020 12:37
02-19-2020 12:37
I have tried to hold 3 buttons down, it will not turn on. So is this the way of it, is this is a through away?
Best Answer02-19-2020 12:40
02-19-2020 12:40
I'm afraid it probably is now just a throw away.
