Hey there @Txosu_girl, thanks for stopping by! Notifications skip or stop occasionally for several reasons that don't suggest a problem with your device or the Fitbit app.
If you've reviewed the list above and can't get notifications to work, force quit the Fitbit app and reopen it to sync your Fitbit device.
Notifications should work as expected after your device syncs. If they don't, continue with the following steps:
If after following these steps they still don't work, let move on with the following:
Give this a shot and let me know the outcome!
Best AnswerIt didn't work
@MarreFitbit wrote:Hey there @Txosu_girl, thanks for stopping by! Notifications skip or stop occasionally for several reasons that don't suggest a problem with your device or the Fitbit app.
- Your phone was too far away. It must be within 30 feet of your Fitbit device to transmit the notification.
For texts, you have the conversation open on your phone. Your Fitbit device shows new texts you haven't already read.
You changed a related setting on your phone, such as turning on Do Not Disturb, Quiet hours, or Driving mode.- You're using another Bluetooth product. If you have Bluetooth products like speakers, headsets, or car stereos paired to your phone along with your Fitbit device, you may have trouble using more than one at the same time.
- The connection between your phone and Fitbit device is unstable. Bluetooth signals are susceptible to disconnecting or dropping occasionally. If you have an Android phone, check the following:
- Make sure Enable Notification Widget is on. You can find this with the other notification settings in the Fitbit app.
- Make sure Always Connected is on. This improves your Bluetooth connection but also drains your Fitbit device's battery more quickly. Turn it off and on as you prefer.
- The app that should send the notification can't do so.
- Your device was syncing. Syncing can sometimes prevent or delay a notification.
- You just updated the Fitbit app. Restart your phone and try setting up notifications again.
- From the Fitbit app dashboard, tap the Account icon > your device image.
- Tap Notifications.
- Turn off all notifications
- Turn off Bluetooth on your phone.
- Restart your phone.
- Restart your Ionic.
- Open the Fitbit app and turn notifications back on.
- Sync your phone
- Tell your phone to "forget" your device, removing the connection between the phone and the Fitbit device.
- On your phone, go to Settings > Bluetooth and find your Fitbit device in the list.
- Find an option to forget the device.
- Open the Fitbit app and set up notifications again.
Best AnswerYes, their help options for Ionic connectivity with phones are very, very disappointing at this point in time.
They basically tell you that you can't use Ionic with any other BT devices....and even if you forget and unlist every other BT device, Ionic still will not be able to keep a stable BT pair/connection to your phone.
It sounds like there is something fundamentally unstable and wrong in their BT radio/firmware on the Ionic and it was not adequately tested before being pushed out to us...and it's been out there for three months and they still do not have much helpful to say.
Best AnswerI finially got it to work .... have you check the notifications setting in the app? It was so crazy trying to find the toggle that I happened to stumble upon it while fussing with it
@Staton wrote:It didn't work
- Sync your phone
Best AnswerWhat was it exactly that that made it work? I get all other notifications pretty steadily after last update but phone calls do t come through till after it's gone to VM. I'm testing with my landline and phone is next to ionic.
Thx
