11-14-2017 20:44
11-14-2017 20:44
Hi, I just bought a Fitbit Iconic as my first fitbit, and hope I haven't wasted my time with a slight overlook in my research.
I need to know, is there a way to increase the duration the clockface stay lit up? As I work as a paramedic I need it on for at least 15 seconds to check heart rates and respiratory rates many times throughout the day, and without this ability the watch is useless for me.
I see that a certain clock face has a built in stop watch that allows this, but that doesn't work as I also need to know the time for drug doses and documentation, and won't be able to constantly switch between the 2.
Best Answer11-14-2017 23:28
11-14-2017 23:28
No it doesnt. But it does have a timer app that you can set for 15 seconds and it will vibrate at the end of the set period. That may work for you - you'd need to play with it a bit to find out. But the screen wont stay o except during some workouts I believe you have that option.
Helen | Western Australia
Best Answer11-15-2017 00:19
11-15-2017 01:27
11-15-2017 01:27
Mine doesn't have those settings, and I only bought/updated it today. Is there a way to force another update I might be missing?
11-15-2017 02:28
11-15-2017 02:28
Wow - what a great idea. Thanks @SunsetRunner. Mine doesnt have it either. Is there a new update out?
Best Answer11-15-2017 02:46
11-15-2017 03:01
11-15-2017 03:01
Ahh OK that makes sense. I am on 27.25.16.7 which as far as I know is the latest one. Well I await the update with interest!
Best Answer08-10-2019 19:07
08-10-2019 19:07
The Fitbit Ionic has the option to increase backlight duration up to 60 seconds. You swipe the screen across until you set the "settings" icon and then scroll down to the "display awake" option. Tapping on this should let you choose between 10, 15, 20, 45 & 60 second durations.
