Ionic Battery Draining Quickly
All of a sudden my ionic battery drained in three hours three times in a row.  I cleaned contacts with q-tip and alcohol and carefully dried.  Waalaaa works again beautifull
Keep your contacts clean, my pleasure if that helps.
Moderator Edit: Updated Subject for Clarity
3 REPLIES 3
@tubby3007 Welcome to the Fitbit family! I moved your post to the Ionic Board as there are more chances for you to receive an answer to your inquiry here.
Thanks for letting me know about the battery drain you have experienced with your Ionic. That was definitely a short power time for an Ionic battery. Also, thanks for taking the time to share the steps you did in order to have this sorted.
I'm glad you are back on track now. I'm sure the steps you have shared will help other users who might be experiencing the same situation. I will leave here a helpful article that provides the steps you did and some other so any user can take a look at it.
Thanks again for your contribution to the Fitbit forums. See you around! Smiley Happy
Santi | Community Moderator, Fitbit
Like my response? Vote for it! Also, accept as solution!
Yup!  Cleaned watch and cable contacts with q-tip and alcohol then carefully dried. Fixed. Again have a five day or more battery just like brand new.
Moderator Edit: Format
@tubby3007 Thanks for your reply. I'm sure a lot of users will find this helpful to get back on track in case they are experiencing the same situation with battery power.
Also, take a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with on challenges, check this thread to add some!
