01-26-2019 06:34 - last edited on 01-28-2019 14:30 by SantiR
My Ionic battery is draining quickly. It was at 91% last night. At 10 % this morning. Also, it was still on the same stats as last night. Did not clear steps or sleeptime..I woke.up with the same amount of steps as I went to bed with. 😞
Moderator Edit: Updated Subject for Clarity
01-28-2019 14:45
01-28-2019 14:45
@KimmyO Welcome to the Fitbit forums! Thanks for sharing the steps and workaround that helped you out to resolve this. I';m sure your experience will be helpful for other users experiencing the same. I'm glad you are back on track now!
@Whistler888 @johneric8 Thanks for sharing your help on this thread.
@Stng2211 @Minispud It's great to see you in the Fitbit forums! Thanks for reporting that you are also experiencing the same situation with the battery power and syncing. Please try a factory reset as this has helped other users in the past.
Keep me posted!
01-26-2019 07:31
01-26-2019 07:31
Same problem here. Tried hard reset and factory reset and changing the clock face. Still stuck on the same stats from yesterday
01-26-2019 07:37
01-26-2019 07:37
01-26-2019 08:14
01-26-2019 08:14
@KimmyO wrote:My Ionic battery is draining quickly. It was at 91% last night. At 10 % this morning. Also, it was still on the same stats as last night. Did not clear steps or sleeptime..I woke.up with the same amount of steps as I went to bed with. 😞
Sounds like your Ionic might be defective. If your factory reset does not help - contact Tech Support. Many have reported getting a replacement for that problem. So that might be the end solution for you.
01-26-2019 08:18
01-26-2019 08:18
I'm kind of an ionic expert since I've gone through a few of them and dealt with customer service way too many times. May I ask if your watch is less than 12 months old? If so, private message me because I have some very important advice to share with you that I can't on the open forum without fear of deletion.
01-26-2019 08:26 - last edited on 01-28-2019 14:41 by SantiR
I've had a similar issue, now the Ionic won't synchronize with my iPhone. Is this the same problem.
Moderator Edit: Format
01-26-2019 08:27
01-26-2019 08:27
01-26-2019 08:31
01-26-2019 08:31
Can you advise how you got your device synchronising again?
01-26-2019 09:12
01-26-2019 09:12
I did a hard reset and a factory reset. After the factory reset was completed a screen popped up for saying to plug my watch in for calibration . Since then it has been working.
01-28-2019 14:45
01-28-2019 14:45
Keep me posted!
01-28-2019 14:54
01-28-2019 14:54
The factory reset worked to a point.
I now have an issue with All Day Sync not working and also notifications. Seems like an issue with Bluetooth, although it seems as though it's connected.
Get a grip fitbit developers and get a this issue fixed. I'm beginning to lose faith in fitbit as the connection between fitbit and my phone iPhone 6s is very hit and miss.
what do you suggest i do as i'm running out of ideas.
02-03-2019 09:52
02-03-2019 09:52
@Minispud Thanks for your reply and for sharing those details.
If you keep experiencing trouble to sync; please try these syncing troubleshooting steps in order to sort this out.
For notifications; I'd recommend trying these notification troubleshooting steps to sort it out.
Hope this helps. Keep me posted!
07-10-2019 06:16
07-10-2019 06:16
Hi @johneric8 ,
I'd like to send you a pm in response to this old post, but I'm new to fitbit forums and don't know how. I have specific questions about Ionic, as I am going through some issues without the answers I really need.
07-10-2019 08:31
07-10-2019 08:31
09-01-2020 11:52
09-01-2020 11:52
Hi
I was trying all the solutions you have mentioned but unfortunately nones works. Battery drainage still persists. Please advise alternative solution to avoid sudden battery drainage of Ionic.
09-06-2020 22:20
09-06-2020 22:20
Battery started to drain on my Ionic one night. 90 % at bedtime and 0 in the morning. Have done several factory resets since with full charging in between. Is the watch worn out after 2 years? Guess there Is no warranty any longer.. It did coincide with release of the Sense...
12-28-2020 06:24
12-28-2020 06:24
I charged mine yesterday, took it off at 7:30 pm. I did no physical activity and now I'm below 75%. I contacted support through the chat and they told me I'm averaging 3.7 days with my battery and didn't offer any solution. The guy was nice through chat, but I feel like it's not lasting nearly as long as it used to.
12-28-2020 12:11
12-28-2020 12:11
I was wrong, there was warranty and Fitbit sent me a brand new watch! Just made a phonecall to support (in Swedish) and after they logged in and saw the drainage overnight and sent new watch!
01-14-2021 11:16
01-14-2021 11:16
I did the factor y reset, chage face plates, and still draining.
Muy iónic is almost three years. Can fitbit still provide support to a device that old?
01-14-2021 11:51 - last edited on 01-18-2021 18:38 by LiliyaFitbit
I think 2 years but call support.
Med vänlig hälsning
