01-21-2019
10:50
11:14
SantiR
01-21-2019
10:50
11:14
SantiR
From Jan 20, 2019, my Fitbit ionic watch is not turning ON event after recharging. Restart also didnt work and even after cleaning the contact points the device is not working. I am from bangalore and I purchased the watch on Aug 16, 2018. So could you pls let me know where is the service center of Fitbit watches in Bangalore, India.
Moderator Edit: Updated Subject for Clarity
@anshumanbiswal wrote:From Jan 20, 2019, my Fitbit ionic watch is not turning ON event after recharging. Restart also didnt work and even after cleaning the contact points the device is not working. I am from bangalore and I purchased the watch on Aug 16, 2018. So could you pls let me know where is the service center of Fitbit watches in Bangalore, India.
Contact Help Tech Support and see if they can tell you. Normally they do not repair devices. They instead replace them.
11:14
07:40
01-22-2019
11:14
07:40
@anshumanbiswal It's great to see you in the Fitbit forums! Thanks for posting the situation you are currently experiencing with your Ionic not turning on. Thanks for restarting it and for cleaning the contacts in order to sort this out.
If you haven't done so already, please try changing the clock face on your watch. This has helped other users in the past who have experienced similar issues.
There is a contact center for India. Check the details here. However, you can always let me know if the steps above didn't work and I can go ahead and contact them in your behalf.
@Whistler888 Thanks for helping on this thread.
Keep me posted! ![]()
Best AnswerMine has done same thing. Seen Fitbit symbol this morning and now nothing. Can’t get it to turn on. Placing on charge for a while to see if come back. It had 60% yesterday. Just out of warranty by 1month.
01-29-2019
06:48
07:40
01-29-2019
06:48
07:40
@Borris01 I hope you're doing well! Thanks for posting that you are also experiencing this situation. Thanks for sharing those details and for trying to charge it for a while to see if it will come back.
By any chance, have you tried performing a restart on your watch? This has helped other users in the past.
You could also try these tips to fix batteries that are not charging and also try changing the clock face. This has helped other users in the past.
Try that out and let me know how it goes! ![]()
