07-31-2020 07:20
07-31-2020 07:20
I see many old threads on this topic but none seem to have answers.
My Ionic is 13 months old (or course 1 month past warranty!!!) and will no longer connect to the GPS. I have done a factory reset. I have tried setting it outside by itself with a clear view of the sky for up to 20 mins. I have restarted it many times. This isn't just happening in my neighbourhood (and I dont live in the middle of no where), but everywhere I have tried. I typically had always had to set it down for a couple of mins to connect but now it never does.
Has there ever been a solution to this? This is the reason I bought this watch and I feel like it should work for more than 13 months!
Thanks!
Best Answer07-31-2020 10:17
07-31-2020 10:17
I had this problem too. I found that just setting up GOS on the AP is not enough. When you select run, a cog wheel for settings should be in the corner. You have to click this also and set it to GPS.
