11-02-2020
05:33
21:54
RicardoFitbit
11-02-2020
05:33
21:54
RicardoFitbit
My ionic takes a long time to connect to GPS - like 5 minutes or more. I try setting it going a minute before I start my run but it still doesn't pick up.
It didn't used to be this bad, I make sure that I do all the updates it asks for. The GPS was the reason I got the ionic 2 years ago, and I'm not ready to upgrade it yet.
21:54
06:03
11-02-2020
21:54
06:03
Hi @elizastarbeth, welcome to the Community Forums!
Thanks for bringing this to our attention and for the details that were shared in your post, I understand how frustrating this matter can be for you. If you haven't already done so, I recommend you to check the steps that are specified on our help article: Why isn't GPS working on my Fitbit device? and let me know if the issue persists after taking them into consideration.
I'll be here if further assistance is needed.
Best AnswerI had intermittent GPS and more importantly, the IONIC stopped mapping runs.Ionic watch straps do not last long - so I got a third party band (specifically a metal dress band). This was when the problem started.
I then order the traditional plastic strap and put that on. Again everything worked fine.
I suspect that if your watch stopped tracking and you swapped your band recently - take your band off put the watch face in your pocket and go for a run. Then go out and buy a different strap.
