08-28-2018 06:12
08-28-2018 06:12
Hi All
Wondering if anyone might be able to assist. Is it possible for the fitbit to show HR% rather then the number? I have hunted around but cannot find anything settings wise.
Thanks!
Best Answer08-28-2018 14:48 - edited 08-28-2018 14:50
No, that is not available. You can suggest that it be made available in the Features Suggestion Forum.
Best Answer08-28-2018 07:19
08-28-2018 07:19
Heart Rate as percent of what?
Best Answer08-28-2018 14:00
08-28-2018 14:00
% of your calculated maximum.
The "avg" max or upper limits is calculated by taking 220 - your age and that is your theoretical maximam.
If you can view a % this helps get in and out of your target zones. Its very helpful when training especially if you are doing a recovery session
Best Answer08-29-2018 04:04
08-29-2018 04:04
thank-you!
