11-29-2018
05:08
14:41
SantiR
11-29-2018
05:08
14:41
SantiR
Fitbit ionic is not turning on, have left it on charge for 2 days have cleaned the pins have tried the reset procedure and it still won’t turn on
Moderator Edit: Updated Subject for Clarity
Best Answer11-29-2018 05:50
11-29-2018 05:50
I would suggest contacting customer support in this case. They will be able to discuss which warranty options might be available to you.
11-29-2018 06:41
11-29-2018 06:41
12-02-2018
14:41
03:53
12-02-2018
14:41
03:53
@Tynan85 Welcome to the Fitbit forums! Thanks for trying cleaning the pins, restarting, and charging it completely in order to sort this out. Also, thanks for contacting customer support regarding this.
Did you got any answer from customer support regarding this? Please let me know!
@N8teGee Thanks for sharing your help on this thread.
Keep me posted!
Best Answer12-02-2018 17:39
12-02-2018 17:39
07:36
03:53
12-04-2018
07:36
03:53
@Tynan85 Thanks for your reply and for sharing those details. I'm really glad to read that customer support identified the root cause of this and that are now replacing your Ionic.
Once you receive the new unit; please feel free to follow these replacement set up steps for you to not loose any of your previous data.
Hope this helps. Keep me posted! ![]()
