I have a strong guess about what could be the problem with Fitbit Ionic sync in one certain case.
If you encounter the following problem, please help me out and check the following.
Case:
In this case, please check the following:
So my assumption is that the Ionic has a problem with certain WIFI setups that also affects the sync process, to be exact: If your router provides both the 2.4 ghz and the 5 ghz network with the same SSID. (There have been similar cases in the past eg. with Amazon Echo devices. Your phone is probably using the 5 GHZ network and configures the corresponding MAC address on the Ionic, but the Ionic only supports 2.4 GHZ and therefore has the wrong MAC address of the 5 GHZ network instead of the 2.4 GHZ network.)
IF this is the case, it will not help in other cases that may also exists, so please just add to the thread if you encounter problems as described above to narrow down the problem.
GOOD LUCK IONICS and thanks for your support!
Best AnswerIf I'm right you have the following options at the moment:
