06-26-2018 23:51
06-26-2018 23:51
Has anyone experienced the numbers on your screen looking jumbled or not displaying correctly?
Best Answer06-27-2018 03:17 - edited 06-27-2018 03:18
Are you using a Fitbit watchface? If not try one of the fitbit ones and see if it displays correctly. It may be a problem with the clockface you are using.
You coukd also try restartingbthe ionic a few times and see if that fixes it. Restart your tracker
Helen | Western Australia
07-02-2018 09:40
07-02-2018 09:40
Yes. Still looking for a solution.
Best Answer07-05-2018 08:20
07-05-2018 08:20
Thanks for the info! I figured it out. I just had to go back into the watchface options and choose the one I liked again. Apparently, the option must have had an update and all I needed to do was to make sure my watch was updated with the latest and greatest!
