Hi,
I am having issues synching my Ionic with my Honor View 10.
Sometimes works, sometimes doesn't. Was fine until the new firmware uodate.
I usually need to delete then re-add to get it to work.
Is this a problem being worked on please?
Thanks, Gavin.
Best AnswerIn that list there are only older phones, and very few, if you change with some smartphone of 2017/8 how can you do?
Best AnswerThis is exactly the problem I am having same phone, worked absolutely perfectly until I updated to V2.1.
Now it will not connect at all. It is not acceptable that fitbit expect their users to only use a small number of obsolete old fashioned phones, this is the real world, not the world according to fitbit.
I am curious if gavinbrad found a fix. Please don't respond with the phone isn't on the list of compatibles, if it worked perfectly before what have fitbit done to now make it incompatible?
